Hey All,
So - I think I have it narrowed down my issues - and I think I just have to replace the fixture....but I want to be sure I'm not missing something! I put in a new bulb to the fixture to test everything out - Here's what I have.
-Tested the bulb with continuity (base of the bulb) - good.
-Tested the output of the transformer (PX300) - 12V - good!
-I followed these directions:
- and didn't come across a ground fault. (Good...I guess?)
-Tested the continuity of just the fixture at the junction box (which is the transformer) - black to the white wire from the multimeter and got nothing. No change in the multimeter at all.
I had a previous post where they previous owner converted the 120v pool light to a 12v with the PX300...but didn't change the housing (it's a 120v Hayward Astrolite SP0583L) and was wondering if that was causing issues - but I think there is something in the wiring of the housing now. Signs are pointing towards a new fixture, but just wanted to check with folks much smarter then I am on the matter!
And if I need a new fixture definitely go with the 12v version of the Astrolite correct? I purchased an LED bulb that is 50w (one of the recommended ones here), but I think sticking with a 300w enclosure would be a safer bet...or get the 100w fixture and stick with LEDs moving foward?
Thanks all!
Thanks all!
