- Sep 9, 2017
- 36
- Vinyl
- Pentair Intellichlor IC-40
Hi All,
I made the decision to swap out our 120v Pentair LED lights with newer 12v lights. It wasn't until after that did I realize it may not be as simple as I thought (or maybe it is). That's the point of this thread. Electricity is dangerous. My plan is to have an electrician come out and check everything once its done and before I ever provide power to the lights but I wanted to see if I could get some input on the best way to organize everything as I would like to learn and do some of the work myself.
My Questions:
1. Is it safe to have 12v DC and 120v inside the same conduit? I read a number of articles that said it was safe in most scenarios but google isn't a real electrician.
2. Assuming this isn't an issue, what is the proper way to wire things inside the EasyTouch when trying to keep low voltage and high voltage separate but having to send the wires down the same conduit? I'm under the assumption that its the connections that are most important to keep separate but again, what do I know.
In my diagram, how do I connect A with B? Should I use a conduit T so they don't join until outside the box? Does it matter?
Thanks so much in advance for all suggestions!
Current Wiring
Note: The conduit coming from poolside back to the EasyTouch panel contains BOTH the 120v Pool wires AND the 120v mains power.
And here is how the EasyTouch side of things look when the Transformer is added:
My Questions:
Current Wiring
