Hi all,
I was wondering if the backside of a raised pool wall should have the tiles or not. Something like the picture attached where the travertine tile is on the backside.
My PB most likely won't install the travertine tile on the back part of our raised wall since my neighbor also used the same PB recently and did not have the tile on the back. The PB just put the textured decking material on the back side.
Any thoughts on this and if the back is typically tiled or not? Would it even be worth paying for the tiling on the back? Our pool has a manual fire strip on the wall that I would go back to turn on/off so would be seeing the back of the wall often enough I guess.
Thanks!
Thanks!
