Pool heater repair
coryp
0
Nov 6, 2007
54
You were spot on, the size and shape of the non-OEM oring was off. What an awful piece of kit. The OEM bypass kit has the correct gasket. It has an oval shape, meaning the circumference of the actual gasket material is like a flat oval shape.
Anyways, it’s all getting returned since I’m having to get an entirely new heater.
i know this is old, but was your heater also an IDL H400? i'm curious as i got a replacement oring for mine that is identical to @swamprat69 and i'm fairly certian it is an OEM hayaward ring, but it is round, not oval as you are mentioning. wondering if your model has that shape and OP does not...
found some more details in another, post adding for ref.
