I have an electric pool heater which works but the compressor never shuts off.
Everything works, that is, I set the desired water temperature, for example 85 degrees, and the pool heater fan and compressor are on and hot water comes into the pool.
When the pool water temperature reaches the set temperature, the fan turns off but not the compressor - it stays on.
Even if I press the Off button on the heater - the compressor keeps running even though the panel shows "Off".
So what happens is that the unit ices up.
The only way I can get it to stop is to turn off the breaker to the unit (obviously).
I checked the contactor relay inside the unit and it's not stuck - when I turn on the breaker the contactor closes and when I turn off the breaker it opens.
Any ideas on what the issue could be ?
