Pool cove size for oval?
Castilloj73
0
35
Haiti
Hello guys, I have the swim and play Yorkshire 18x33 oval and I’m about to change the liner.
I wondered what the height of the cove should be on the middle walls by the supports?
Last time I installed it I went over board and made the coves in the middle about 12 inches off the wall and 6 inches high.
Should the cove be the same all around the pool?
I also have the foam cove underneath the sand cove.
Thanks.
You shouldn't need the foam cove and sand cove. Personally, I'd just do the sand cove unless it is a lot of extra work to remove the foam cove. The cove is typically the same all the way around the pool. I'd say a typical cove is 4-6 inches wide and 4-6 inches high. Cove can be flat or circular.
I suppose you could make wide coves if you had a specific desire to do so, but they aren't typical.
Liner floor pad is optional
