Pool coping out from above liner
rlavoie12
18
Attleboro MA
Hi all!
I live in Massachusetts where the weather has just been crazy. Long story short couple weeks back we got a huge snow storm (2 and a half feet). I have a skimmer plug and return jet plug which overall has been good kept water high. However, I do not know if the water got too high because the black plastic coping that goes over the liner for 2 of my walls has came off the liner and pushed towards the inside of the pool. I was able to pull one back on one of the walls and snap on but other 2 having difficulty. I posted a picture to show what I mean. So where the pool wall is and the liner that goes a little over the black coping bar that is there came a little off and towards the inside of the pool. Pool was only installed last July. Understand with snow and everything that this can happen and I really meant to close it right and though skimmer plug, pillow, return jet, cover, thought I did it right but guess just had this issue. Can someone please just give some advice? Realize I may have to wait for a good thaw first though or make sure to have installers come?
Thank you!
Is it broken or just lifted? When things thaw & u can pump some of the water out you should be able to just put it back in place/replace it. Just remove the top rails 1 at a time to get to it. The top rails should hold that in place. When that time comes post some pics & we can give u more detailed advice .
In the future try to keep the cover pumped off as it rains as the weight on the cover displaces the water in the pool. You also may want to lower the water level more in the pool when winterizing to allow for more room when snow/ ice occurs that can’t be pumped off the cover.
Looks like just lifted not broken. Thank you cover decided to blow off with the winds! So pumping water out of the pool right now think should be okay I hope!
