Pool automation using Sonoff 4CHPRO with Intermatic PE24VA valve actuators - Need Help
surprise-pool
3
Surprise Arizona
I'm stuck ... I'm building out my own pool automation enclosure and I have something wired wrong. I can't get the Intermatic PE24VA actuator valve to turn using a mean well 120v - 24v power supply controlled by a sonoff 4CHPRO. It doesn't matter what mode I place the actuator in Auto Mode 1 or Auto Mode 2, no movement. Appreciate anyone's feedback for correct wiring and components needed to make it work? Thanks so much.
How was the sonoff configured for the valves?
What are you trying to accomplish?
I plan to control two valve one for our bubbler and the second actuator for our deckjets. The sonoff 4CHProR3 as the controller to be able to connect it to our Google home. I plan to hook it up as shown in the OP. I haven't messed with the 4ch but assume it similar to the single ch unit. I'm trying to avoid damaging the controller or actuators.
Did you get this working? I'm looking to control my valves as well, I have various scenarios and I'm always manually flipping the valves to control what I want to do. I don't have any pool automation today, so looking to primarily be able to control my pool valves from HomeAssistant.
Check out the low budget automation link in my signature. To control the valves, you need 24 VAC capable of .75 amps per valve. You will also need a power supply for the wifi switch/relay itself. The relays I selected accept 24 VAC input so I could power the relays and the valves with one power source. I use Alexa routines to control automation.
Thank you! That's an awesome build and great write-up. my only hold-up is trying to find something that will integrate cleanly into homeassistant. I've made a deal with myself to not install another app again...everything must integrate!
I'm not sure what you mean by "integrate" with Home Assistant, but all of the devices that make up my automation system do show up in the Google Home and can be controlled via Home Assistant.
I haven't updated my automation thread yet, but I did add heater control utilizing a Sonoff TH16 switch with probe.
Reactions: jryan82
I did get it working this weekend. My current automation would be an intelliconnect and suntouch for the solar. Haven't figured out how to interconnect the two so when the suntouch is activated the pump can switch to a specific speed when still connected to the intelliconnect.
I did read some advance setups but the connections and code is a but over my head.
For what is did, I only needed to control 2 actuators. I used the sonoff 4chpro with a 24vac transformer to do what I needed. It was based off another user drawings. It used the inching setting to delay it for about 45 seconds then shuts off. It takes two relays to control one valve? One relay to rotate CCW and the other CW. It could be an issue if both are turned on at the same time. I was able to connect this to my Google home system.
I know I am late to the conversation, but I was thinking... why power the transformer all the time. Why not power the transformer by one of the channels, with the same power feed you are using to power the board? you would need to turn on that channel every time you wanted to move the actuators, but I think saving the transformer would be worth the little extra effort.
Update: The diagram I used above to illustrate adding a relay to the transformer has worked great. very simple little project. I like that the transformer is only powered when the actuator is needed.
