Polymeric Sand for Expansion Joint?
manthemike12
31
Boston, MA
Pentair Intellichlor IC-40
I bought a house with a pool outside of Boston this spring and noticed issues with the expansion joint. I'm referring to the expansion joint between the coping and paver pool deck. It seemed to be deteriorating in some places and the expansion joint is of varying widths.
Upon closer inspection I found that polymeric sand was used over foam backer rod. Is polymeric sand acceptable to use in this joint? I have bought Deck o Seal and will be replacing it. 20210923_091641.jpg
What you can do to improve the look of the new deck-o-seal joint, is to sprinkle sand on the wet joint. It's a nice finishing trick.
Reactions: Aquaman7
