Polaris not moving.
Jesusfreak
190
Mesa, AZ
I believe the rubber is worn out. Will that cause it not to move. I see the single wheel on the left rotating. It has two big wheels and one small wheel on the right.
What model Polaris cleaner?
It is usually a clogged jet or water hose.
Check that the pressure relief valve by the quick disconnect is not leaking.
Check no hose joints are leaking.
Several things to check. Need to verify what model you have.
There is a screen filter close to the wall connection. Confirm that is not clogged.
Then confirm you have good water pressure to the unit. When you take the net bag off and booster pump on - do you see water jets shooting up towards the opening where the net bag was?
Are the rubber on your wheels gooey? If so, time to replace them.
For the most part, if unit is not moving, it is about getting pressure to the turbine that drives the wheels. Any lose or reduction in pressure will slow the cleaner.
Reactions: Jesusfreak
It is a Polaris 280.
Get the tune up kit or rebuild kit and it should make it run like new.
