Polaris 360
rocco24
1
92804
I have about 6 return lines plus one line dedicated for vacuum cleaner. The water flow is too weak to make the Polaris 360 operate efficiently. Is there anything I can do to kind of improve that water flow?
I was thinking of using some plugs for some of the return lines to restrict the water flow but I am concerned about the filtration system. Is there anything else am I missing? my Polaris barely moves :(
Welcomed to TFP.
How old is your Polaris 360?
What model pump do you have?
What valves do you have to adjust your return water flow?
Has your 360 ever worked correctly?
