I have a polaris 280 and I was wondering if adding more swivels to the feed hose would keep it from looping and twisting up. I think there are 3 in the feed hose line now but it seems there is too much hose between the swivels. I have played around with the number of floats and the positioning but it doesn't seem to change it. The swivels I have turn freely and don't leak. Only concern is would more swivels actually impart some additional flow restriction.
Pool is inground 16x32 vinyl liner.
Background:
I recently brought this cleaner back to life. It came with the house but had been sitting for a while and appeared to be junk. Had to replace the pump volute and seals, and replumb it with flexible piping since the hard pipe was broken. Needed things like o-rings in the reverser. a wheel screw, and new catch bags and after all that it works quite well. I had to fine tune the head float to get it to climb the vertical walls. No thruster repositioning necessary. It operates fine on the blue restrictor plate which is what it had originally. I also reduced the flow on the tail whip a bit but I still have to verify wheel RPM.
Background:
