- Mar 10, 2018
- 83
- Plaster
- Jandy Aquapure 1400
i have an old Polaris 280 which leaks at the swivel where it connect to the hose. Tightening the nut did not help nor did cutting off an inch or so of hose to provide a "fresh" bit of hose at this connection. 1)
Could it be that the hose is so stiff with age that the teeth of the nut threads are not cutting into the outer surface of the hose deeply enough to support adequately squeezing the hose against the swivel barb?
2) Is it merely problem of my not applying enough torque?
3) Should I splice in some new hose?
David - Dallas
David - Dallas
