Plunge Pool - AUS
Welcome to TFP! :wave: Once a salt pool's water is initially balanced, it typically requires muriatic acid to control the pH. Occasionally you may have to add more salt or stabilizer (CYA). If the TA falls below 50 some baking soda. If it's a plaster pool, perhaps some calcium. That's about it. I like to keep a gallon or two of liquid chlorine in the laundry room for emergencies if the salt cell acts-up and the FC crashes for some reason.
Be sure to visit our Pool Care Basics page for lots of articles that will answer just about all of your pool questions.
As always, be sure you are testing your water properly. In your area, TFP member go to Clear Choice Labs for the equivalent of the Taylor K-2006C test kit.
Enjoy the forum. :swim:
