Please Help
KaylaB88
6
Atlanta, GA
I currently have a 20 by 52 in round above ground pool and the current pump isn't cutting it. Me not knowing much about pumps got a 2 HP pump on sale so I snagged it. I'm wondering if I pair that with a 16in sand filter would that be a good combo or is the pump to big for my pool? Any all suggestions appreciated thank you!
The flow it barely pumps at all it's a smaller cheaper pump I knew beforehand that the pump was an issue because of the reviews 9 out of 10 said they had to replace the pump because it wasn't sufficient enough for the pool the flow is absolutely horrible.
The filter is the a/c filters white with a blue rim and No it doesn't make the flow any better when I remove the filter. I just don't think the small pump has it in it to properly circulate and filter that much water and I'm running it almost all day
Also I don't have the sand filter that's what my question was I'm trying to figure out if the new 2 HP pump I have still in the box along with a 16in sand filter I was looking at buying will be efficient for a pool this size or if the 2 HP is to big for this pool and a 16in sand filter (if that makes sense)
Reactions: kne
Also, is this an intex style pool or a permanent above ground pool?
Can u provide a link to the filter you are looking at?
I have this pump not sure if it is a single or 2 speed also attached is the sand filter I was looking to get and a picture of my pool with current pump
Reactions: Mdragger88
You have already bought the pump? Can u return/exchange it? This one would be a better fit if u need to stick w/ this vendor
not sure about the quality of these pumps though.
If you can just return it & get your $$ back get something like this one - supposed to have a 1yr warranty.
XtremepowerUS 75113 Pump Pool ABOVEGROUND 1.5HP 2SPEED Energy Saving, Black https://www.amazon.com/dp/B07XZL91MV/ref=cm_sw_r_cp_api_i_YEYK377MK9ACGFKPCTR6
