My wife and I recently moved our family of three girls to Florida last summer. We looked at many homes with pools during our search but most did not have a spa which was a must for us and or we just didn't get the "feel" from the pool and or outdoor space we were looking for. We decided to change our search to the actual house and neighborhood we were looking for with no regards to a pool or not with the intention of putting one in. We love our new home but now we need the pool.
We have met with five different pool builders(well salespeople) in our area and have pretty much narrowed it down to one. We are hoping to make a decision and sign a contract next week in order to get it started as soon as possible. I found your forum a couple of days ago and have been reading as much as I can. I was hoping to get some feedback on the bids as well as ask some questions concerning the choices(lighting, finish and spa height) we need to make soon. The guest/Pool house to the left of the pool in the photo is not there yet that was left over from an earlier full backyard design and will have to wait for another project.
Pool: 28'8" x 16'4" (366 sq') 3' to 5'6" depth
1 Year Warranty On All Workmanship Of Your Superior Investment
Web Based Communication Scheduling System Used To Build Your Pool. You Receive Your Own Personal User Log In
6” 4000 PSI Concrete Shell With (LIFETIME STRUCTURAL WARRANTY)
Minimum 3 Yard Stabilization Rock Under Swimming Pool Shell (With Sump Pump System)
Three Large Steps In Shallow End / Swim Out In Deep End Per Code (With 1x1 Glass Diamonds)
Stone Scapes Certified (Regular Pebble) 5 Standard Colors (LIFETIME WARRANTY INCLUDES LABOR)
2 Pentair Glo Brite LED Color Changing Lights http://www.pentairpool.com/pdfs/GlobriteDS.pdf
All 2 Inch Schedule 40 Plumbing Suction Lines (Per Code)
Vacation Setting Valve (3 Way Valve So You Can Shut Your Skimmer Off When Out of Town)
Oversized Concrete Equipment Pad
Automatic Timer With Transformer & Breakers (All In One Panel)
All Swimming Pool Electric (Per Code) Installed (30 Amp Breaker)
60 amp Breaker for Heat Pump
AquaCal SQ145 Heat Pump
Automatic Dedicated Over Flow System
4 Adjustable Returns (Self-Regulating Paramount I-Jet Return Inlets) iJet - Paramount Pool and Spas
Unblockable 32 Inch Channel Drain 640-136 XV Packaged With An Oversized Admiral Surface Skimmer
Decorative 6 x 6 Waterline. Your Choice Of Ceramic Or Porcelain Waterline Tile
Pentair Oversized Intelliflo Variable Speed 3 HP Pump VS http://www.pentairpool.com/pdfs/intelliflovspeedwtimerB.pdf
Pentair Oversized 150 Clean & Clear RP Cartridge Filter http://www.pentairpool.com/pdfs/intelliflovspeedwtimerB.pdf
Pentair Oversized Intellichlor IC-40 Salt System (Salt Included) http://www.pentairpool.com/pdfs/intellichlorDS.pdf
All Pentair Products Include An 3 Year Warranty (Superior Pools Handles All The Warranty & Docs)
Paver Deck: (626 sq') under Lanai (239 sq')
Compaction Of Soil With Heavy Jumping Jack Compactor
2” Deco-Drain & Termite Spray Installed (Per Code)
Poured 3000 PSI 8 x 8 Footer With (Fiber Mesh, Bonding Grid Around Entire Pool, #5 Rebar)
Bullnose Thick White Cement Coping (All Colors Are Standard) Coping Colors - TriCircle Pavers
Matching Colored Grout Included http://www.sgm.cc/pdf/Grout_Color_chart.pdf
Thick White Cement Pavers (All Colors & Patterns Are Standard) Pavers - TriCircle Pavers
Minimum of 2 Inches Of Crushed Shell Base Installed & Compacted
Toping Sand Installed Over Entire Surface (Used To Lock In Pavers)
Large Border Installed Around The Whole Deck & Lanai
Two 4 x 4 Paver Door Pads Installed
Spa: 6' Round 3'6" Depth
14” raise
Screen Logic App
Double Row Bullnose Thick White Cement Coping (All Colors Are Standard) Coping Colors - TriCircle Pavers
(4) Therapy Jets
1 Pentair GloBrite LED Color Changing Light
1 Spillway
Pre-Plumbed to make therapy jets more efficient with better pressure
Cage: Mansard Style
Cage Installed By ABSOLUTE ALUMINUM ONLY (Partnered With Superior Pools Only)
Protect Screws & Caps Throughout Entire Cage (Prevents & Rust Corrosion)
Two Screened Doors with Key Locks
Mansard Screen Enclosure, Bronze or White Sarasota Outdoor Kitchens | Pool Enclosures | Pergolas (941-497-7777)
We Partner With Absolute Aluminum. The Will Not Install For Any Other Pool Contractor
Extend 7” super gutter to end of house
Complete Cost Of Investment:
State Licensed (#CPC14566447) Fully Insured & Bonded All Taxes & Labor Included
Superior Pools Builds 90% Of Your Swimming Pool In-House. Compared To The Industry Average 10%
All Permitting & All Engineering Costs Included
Battery Alarms Installed By Superior Pools To County Code, Accept All Responsibility
Full Time Warranty Staff With 30 In-House Employees
WE GUARANTEE 40 DAYS OR LESS (From Breaking Ground To Water In Your Pool)
Rated One Of The Top 50 Pool Companies In The Nation By Pool & Spa News
Gulf Coast Top 500 Companies 2010, 2011, 2012, 2013 2014 2015
Superior Service Award on Angie's List 2013, 2014, 2015
Member of the BBB A+ Rating http://www.bbb.org/west-florida/business-reviews/swimming-pool-contractors-dealers-
design/superior-pools-of-southwest-florida-in-port-charlotte-fl-90008202
Member of Houzz Superior Pools - Port Charlotte, FL, US 33953
Member Of Guild Quality Please Read Our Reviews Superior Pools Of SW Florida of Port Charlotte, FL | reviews and customer feedback from GuildQuality surveys - GuildQuality
Read Our Reviews Pool Design & Building in Port Charlotte FL by Superior Pools
You Only Build A Pool Once, There Are No Returns Or Refunds, Best Advice, Do Your Research
Our Competitors Quote The Least Expensive Pools Then Add Charges During Construction Buyer Beware.
GUARANTEED NO ADD ON CHARGES
$61,682.00
This by no means is a final plan as we have reservations about the price and are concerned about whether the finish we want is included or extra. I am also concerned whether the two lights are bright enough for the pool as they are listed everywhere as shallow water lights.We have other concerns as well but I do not want to go on and on in my first post. Hopefully this is enough to get started and introduce myself. I greatly appreciate any and all feedback.
Dennis
14” raise
Screen Logic App
(4) Therapy Jets
1 Spillway
Cage: Mansard Style
$61,682.00
Dennis
