Hi! We moved into our home 4 days ago. We did swim in our pool a few times but it’s also been storming and raining a bunch since we moved in. We didn’t do anything the first 3 days. On the fourth day when I got home from work we noticed some cloudiness. I tested the water and FC/TC was low, Alk was low, pH was 6.4, Cya was low and TH was normal. We have a 20,000 gallon pool and I dumped 8 lbs of baking soda in and a gallon of chlorine. Retested this morning and everything except pH was okay (6.8). I added another 4lbs of baking soda. We tested again around noon, pH still at 6.8 and chlorine had dropped, so added more chlorine and 4lbs baking soda. Tested again tonight and chlorine is back to good and pH is still at 6.8 and the pool is still very cloudy. My plan is to continue to add baking soda in the 4lb increments until pH is balanced. Is this the right path or should we do anything else. Thanks in advance!
