- Dec 4, 2018
- 7
- Plaster
- Hayward Turbo Cell (T-CELL-5)
I have a small (5000 gal) concrete in-gound pool with a spa. The chlorine generator works well to keep free chlorine at a good level. My Ph, however, is ALWAYS high. If I add 24 oz of dry acid, the Ph level will be good the next day. Then the following day it will be above 8. I've been told a chlorine generator produces chlorine at a high Ph. What is going on? Should I just live with a high Ph? Should I add dry acid every other day or so to try to keep the Ph at a desirable level?
