We had a new roof put on 8/9. The pool was tarped but the tarp was full of nails and shingle material and had taken on some water, therefore the roofing materials were marinating in the water for several hours, and that water eventually made it's way back into the pool.
Ran TF-Pro tests the next day on 8/10 and pH was a magenta color that was off the charts alkaline and TA was 130.
In the evening on 8/10, I added the PoolMath recommended amount of Muriatic Acid to drop the pH to 7.2 and turned on water feature to raise pH via aeration.
The next morning on 8/11 pH was 7.5 and TA was now 40. PoolMath recommended adding about 9lbs of baking soda which I did not do immediately. Instead I added fill water (pH 7.8, TA 160). Tested again a couple hours later and pH was 8.2 (or higher?) and TA was 80.
Tested on 8/12 and now pH was 7.8 and TA was 50 so I added 3lbs of baking soda to target TA of 60.
Tested again today, 8/14, and now ph is very high again rich pink magenta color so 8.2 or higher and TA is 250!!!!
At this point, I seem to be bouncing back and forth between low and high TA. Should I be taking more subtle steps and waiting much longer between the steps? Pool pump runs several hours after any chemical addition that I make, so mixing should be thorough prior to testing.
