I have a Pentair Thermo temp 400 that was having an issue with cycling on and off once it reached 90*. I bought a kit online and replaced the stack flue sensor, Thermistor, pressure switch, gas shut off, and high limit. I also replaced the thermal regulator.
Now the heater comes on and heats to 90* and then powers off.
After setting for a bit and cycling the circuit breaker it will power back on and do the same thing again.
I would appreciate any direction that can be given.
Thank you,
RDB
Thank you,
RDB
