Hello all,
I have a circa 2006 Pentair Tagelus TA100D. I can see water coming out between the tank and the first plastic insert, so figuring the o-ring needs replacement. (See blow-out diagram)
It's leaking between part 3 and the tank... so I want to replace the o-ring part 4.
Question is.... Does the whole unit (part #3) just unscrew? Counterclockwise? I didn't want to force anything if I was doing it wrong.
When putting back together I was going to spread some pool o-ring lube and re-assemble.
Thanks for any help provided. Cheers!
