pentair tagelus TA 60D sand filter
Apr 24, 2016
1
Seattle
While deep cleaning out my sand filter I discovered that the lateral assembly used appears incorrect. My filter is a Tagelus TA60D which uses 8 laterals and the part I pulled out of my filter has 6 laterals. Question is how much of a difference will this have made?
Thanks
James
15,000 gallons, In ground, Plaster, pump is a Zodiac FHPM 1.0
Probably not much difference in filtration. You might get a little more flow through the filter with more laterals (more available suction area = less restriction) but it should be fine with 6 as long as your filtration is working as it's set up.
