Pentair SPA light relay/control switch
sapool101
6
Brentwood,CA
Need help to change the Spa light control to different Aux. I have a color changing pool light but my Spa light is steady warm colored. The previous owner had the spa light configured in the Solar switch on easy touch control panel. I recently installed solar pool heater and now the Spa lights up whenever solar heating is on. Would it be possible to move the Spa light control switch?
Sa,
You have an EasyTouch 4 which comes with a Pump/Filter relay, plus Aux 1, 2 and 3. If you are NOT using solar you can add one more Aux relay.
So, technically, you can't add another relay. That said, you can search this site, for ways to update your board so that it becomes an EasyTouch 8.
You could also just add the spa light to the pool light relay.
Fyi, those Murray/siemens breakers are not rated to be double stabbed as it appears your pump breaker is. It could/would be easily resolved with a pigtail which would be much safer. While you're at it you could swap that breaker to a gfci.
