Maybe this is common knowledge but I thought it would be worth writing up for the next person trying to search.
TL;dr Android SLConfig app does not calibrate sensors. PC version does. iPhone version may.
My pool temp was reading 87F, and my instant read digital indicated 80F. I google searched found a few posts here indicating it could be calibrated using the app
After trying to set it a number of times on my android phone I was a little frustrated the calibration did not take effect.
I searched and read some more and eventually tripped across the thread below which indicated the android app does not work to set the calibration.
Windows PC version does work, and the calibration seems to have remained for several days.
I thought it was worth writing up and might help someone in the future.
link to thread with the answer hidden in it.
Keywords Pentair Easy Touch Water Temp Temperature sensor calibration android SLConfig SL config Screen Logic
Pentair ScreenLogic Reading Incorrect Water Temperatures
Hello, I have a salt system and am using the Pentair ScreenLogic interface. The pool and spa water temperatures showing in the app are significantly different than the actual water temperature. Example: Pentair Screenlogic reads that the water temp is 99degrees, but the in pool thermometer...
www.troublefreepool.com
