Pentair Purex Triton Minimax Plus 400 - Tprobe
Is the Pentair Circuit Board done or just a Faulty Wire that needs to be re-crimped or changed?
YOUTUBE watch here
Picture of the board:
You can replace that temp sensor for about $15.00:
A better use of your money, if there is nothing else wrong with the heater, would be to replace the main gas valve. A valve that corroded should not be in service.
I replaced the Tprobe sensor. Same issue. I have to jiggle the connector with my fingers until the ignition kicks in. It takes a minute to find the right angle to hold the Tprobe connector in place to ignite the flame.
What would be your next step, Circuit board?
btw, i am replacing the main gas valve as well.
How are your soldering skills? May be broken connection on the back of the board.
