Above post
@ycolasan has correct version information.
For anyone wanting more details, below is what I have come across.
Rev MMM - JandyColor
Rev H - Haywood ColorLogic
Rev O.1 - Jandy Watercolors.
Rev T.0.1 has limited support for some early Intelibtight.
Rev T.2 has full Intelibright.
So
@dovsbear any panel Rev T.2 or newer is what you want.
Looks like color light control came in Rev L in 2004.
www.troublefreepool.com
This list provides detail and years behind each of the PPD revisions from Jandy. Additional detail on the changes in each revision can be found in ...
https://www.poolsupplyunlimited.com/Products/Manuals/Sub261_2012329101120.pdf AquaLink RS Software and PCB Revisions Nov., 2011
*A Programmable Peripheral Device (PPD) with revision letter C to HH will operate with all PCBs with a 44 pin socket.
*A Revision I or II PPD will only operate with a PCB which has a 44 pin socket and is a Revision I PCB.
*A Revision J or newer PPD will only fit into a PCB with a 52 pin socket (second generation of PCB).
*1994-Rev. A = Alpha testing.
*1995-Rev. B = Beta testing.
*1996-Rev. C = First production AquaLink RS.
*1996-Rev. D = Allowed Cleaner JVA socket to be assigned to an auxiliary by turning on dip switch 7.
*1996-Rev. E = Programmed ON times not recognized after freeze protection activates.
*1996-Rev. F = RS 2/6 Sharing a heater support, light dimming on RS 4.
*1997 – Rev. G = First support for SpaLink RS, Cleaner JVA can be assigned without turning on dip 7.
*1997 – Rev. GG = Cancel button locks-up system.
*1997 – Rev. GGG = Correction to GG.
*1998 – Rev. H = First support f or LX / RS 485 connection, memory expansion to 128K of ROM, SpaLink reads pool temperature and OFF when the system is not on.
*1998 – Rev. HH = Corrects time calibration problem with Rev. H.
*1998 – Rev. HH 232 = Support for RS 232 Serial Adapter.
*2000 – Rev. I = First support for OneTouch, includes serial adapter support. Note Rev I will only operate in a Rev. I PCB.
*2000 – Rev. II = Corrects problem with auxiliaries assigned to f reeze on OneTouch.
*2002 – Rev. J = Change to 52 PIN PPD and new socket on AquaLink RS PCB.
*2002 – Rev. JJ = Corrects problem with auxiliaries assigned to freeze on OneTouch.
*2003 – Rev. K = Support for FlowLink, items manually turned on will reactivate after going to Auto/Service/Time Out.
*2004 – Rev. L = Color Light Control, PC Docking, Laminar Light Pulse Control (LPC4), Chiller/Heat Pump operation, Run Time (circuits can be set to run manually f or 1 to 10 minutes or for 10 minutes to 2 hours in 10 minute increments). Will communicate directly with AquaPure Chlorine Generator only.
*2006 – Rev. M = Support for AquaPalm wireless remote, Change chlorine production from AquaPure. AquaPure (revision must be 11230A05 or newer). Assign OneTouch buttons to SpaLink RS buttons.
*2006 – Rev. MM = Corrects problem when entering into lights labels.
*2006 – Rev. MMM = Corrects problem associated with daylight savings which caused the AquaPalm to jump lines. Light dimming can be adjusted from AquaPalm.
CPU REVISION CHANGES
*2007 – Rev. N = Complete change to PCB. The operating chip is no longer a PPD, it is now a CPU (Central Processing Unit) board. The AquaLink RS can be connected via the RS 485 line to a Jandy AE Heat Pump &/or a Jandy LXi Gas Heater.
*2008 – Rev O = Communication with Variable Speed pumps.
*2009 – Rev P = Communication with ChemLink, LM3, AutoClear Plus & DuoClear.
*2010 - Rev Q = first support for Touch Screen panel.
*2012- Rev R = internet control of Jandy Aqualink system via smartphone or web
*2013 - Rev. T.2
*???? = Rev V = Rev V and earlier, manufactured prior to mid-year 2022, support up to 4 variable-speed pumps using Dip Switches 3-4 on the pump.
*2022 - Rev W = Aqua-link RS systems using Rev W and later, manufactured after mid-year 2022, support up to 16 variable-speed pumps that utilize a preassigned PUMP ADDRESS.
*???? - Rev Xg - unknown
*???? - Rev Y = Jandy Infinite WaterColors LED Light Controller requires Aqualink Revision Y or later.
*2024 - Rev Yg = Jandy added the ability to have 24 virtual auxiliary assignments.
