- Aug 10, 2020
- 46
- Plaster
- Pentair Intellichlor IC-30
I am having issues with my Chlorinator, looking at the lights and no temperature reading it looks like the Flow Switch is bad, but I replaced the Flow Switch with the factory part and it did not change anything.
The Chlorinator still works although I have to set it at around 85% which is about 30% higher than what's set normally. I cleaned the chlorinator and it did not help either.
Has anyone seen this before?
Does this mean I have to replace the Chlorinator? It has only about 3500 hours.
Here are links to videos for the lights and codes.
Error Lights
Error Codes and Info
Error Lights
