Hello all,
I have had my pool for about a year now and feel like I have a very good grasp on a lot of what has been taught in the TFP threads. However, when I was researching my in-floor cleaner I found a lack of information. I am going to try and help contribute what I have learned in the past year to hopefully help others as this forum has helped me.
My information:
Pool 16,500 gallons with a Spa combo (1 3hp VSP Pentair pump)
Pentair in-floor cleaner (26 Venturi heads, Leaf Vac, Venturi Skimmers A&A Valve)
First, I would like to go over my pump schedule and how I came about RPM/GPM for my pool:
I hope some of this information is helpful for anyone looking for a real-world example of how to run the in-floor.
My information:
- I want to run my pump for 24 hours a day with varying speed allowing my water to turnover at least 3x
- Lowest RPM which my pump can run at is 2200 rpm (43gpm). This allows the flow in my A&A valve to continue the in-floor head rotation. Any lower and the valve refuses to move zones
- I have 2 skimmers which are slightly open as returns using the venuri system.
- Schedule:
- 4 hours at 3450 RPM/85GPM - 20,400 Gallons per day - 1900 watts - Used as cleaning cycle.
- 2 hours at 2400 RPM/50GPM - 6,000 Gallons per day - 763 watts - Used as the Spa cycle to clean dirt from the spa.
- 18 hours at 2200 RPM/43GPM - 46,440 Gallons per day - 620 watts - Used to circulate water at all times.
- Total Gallons moved per day = 72,840 Gallons per day - about 5x turnover
- As mentioned, this is higher than I wanted but due to the minimum RPM of the pump for the valve movement.
- This has increased my electric bill (Austin, Texas) by about $70 per month.
- Heads are not cleaning unless at high speed due to pressure needed to move dirt.
- Circulation is great at all times with this method.
- No Robot required.
- Venturi Skimmers work fine. One of the 2 can be used as a normal skimmer if needed but really haven't had an issue (this feature is to allow for a floor vacuum).
- Heating and Chemical distribution are phenomenal.
- Leaf Vac is easy to clean.
- Higher electric bill.
- High cost to install.
- Tons of extra pipe under the pool.
- Still requires brushing and vacuuming:
- I brush the floor daily, Sides weekly.
- Vacuum monthly.
- I had an interesting issue with the leafvac as well. 3 months into owning the pool I was getting a ton of air in the system. Still all under warranty but the builder could not figure it out. They did a suction side test and found nothing. Finally, the leak was found to be the connection between the leafvac and the pump. once tightened it has worked fine.
