Hi, and thank you in advance for your response. Our Pentair 400 spa and pool heater ignites briefly about 3 to 5 minutes and then the heat turns off but the blower continues to run. The service heater light appears. No error code on display panel. When examining the error lights on the back of the printed circuit board, it appears that the high limit switch fault light is on when this problem happens. is there any way to distinguish between the fault being due to a defective sensor versus the valve. The former is easy to replace, the ladder will be quite difficult as the manifold bolts are quite corroded.
Thank you again.
Thank you again.
