Hey guys I purchased a house with a modest 31x16 pool. I’ve estimated it to be about 20,000 gallons and is being fed with 1.5” lines to 2 jets. Other features of the pool includes a waterfall (not functional as it has a leak currently that will require a decent amount of masonry work to fix) and a couple rotary things on the stairs that creates bubbles (are these bubblers?) I’ve added a pentair intellicenter and a pentair SWG to the pool. It also uses the pentair sand filter and has a 0.5” line connection for the booster pump but I do not use that as I have a robot cleaner.
I’m looking to replace the pool pump with a variable speed that I can control through the automation platform. I figured this would be easy but I’m confused with the reading I’m doing. What is the best pump I could get for my pool? Does it require a cable that I have read I need to purchase separately? (Seems insane it doesn’t come with the pump)
Thanks everyone and sorry for the newb questions I’m teaching myself different things as they come up!
