Pea gravel vs kook deck vs salt on colored concrete
Welcome to TFP!
I like my rock salt finished, colored concrete deck. It has been 100% maintenance free and trouble free for 5 swim seasons and it isn't slippery. There was also no up charge from straight concrete. It is a lot cooler than the flagstone coping. Rocks get hotter than concrete. There are pics in the link in my sig.
Rock (even pea gravel) + Texas sun = burned feet + rocks kicked into the pool
Kool Deck is nice when it is first installed but, honestly speaking, it tends look very shabby in the out years as it degrades and begins to peel and flake. I know lots of people around here that buy homes with pools and rip out the old Kool Deck as soon as they can.
Concrete, when done by a professional that is careful and diligent, looks great and lasts a long time. As long as the installer knows how to grade and prep the sub surface, uses mesh or rebar to reinforce the concrete and knows how to do control joints and mastic expansion joints, then a concrete deck can look as good as any installed hardscape. Stamped concrete is usually the most expensive but it gives you lots of choices for a faux stone look. Acid washing and aggregate exposure can give you a good non-slip surface. Salt finish looks very "antique" and I have lots of salt finished walkways but you need to be careful because it's still a concrete surface with the smooth creme layer intact (unlike acid washing) and so it can get slippery when wet.
If this is new concrete, be sure that you have reinforcing wire or rebar installed and well bonded. Not just for strength, but for good bonding to reduce the risk of stray currents.
