I'm trying to diagnose my sluggish Polaris-380.
Can someone say how much "head" they get from the end of the Polaris hose?
(disconnected before the backup valve... with blue restrictor installed)
I'm getting less than 24" which seems suspiciously low, but I haven't found a spec for the expected head/pressure.
-------- update --------
Solved: I found someone else in the neighborhood with a working Polaris,
and did the head test: ~5 feet! (which would be 2.3 PSI, rather than 23 PSI...)
Yes, the pump was delivering low pressure; the root cause was:
The Polaris plastic interconnect hose was collapsing on the suction side of the pump.
(quick fix: reverse the two hoses, so the weak/collapsing hose is on the pressure side)
