Thanks for the pictures. The valves to the skimmers are OPEN in the picture. Is this the position you say there is no suction when the pump is running?I did a backwash and closed off the valve to the venturi before I add DE to the skimmer but there was no suction to either of the skimmer. Am I missing something? Below are pics of the equipment. Thanks in advance!
Yes. Both skimmer valves open with the venturi valves(2nd Pic, left 2 valves) closedThanks for the pictures. The valves to the skimmers are OPEN in the picture. Is this the position you say there is no suction when the pump is running?
So you should not close both skimmer valves and the main drain valve unless there the SPA main drain is open. Maybe I don't understand what you have done. Maybe a picture of how you have both valves and main drain closed.Hmm weird. Went by 10 mins ago. Did another bw. Same thing I did yesterday. Closed both venturi valve and main drain and there's suction in both skimmer.
No idea what's going on!
Normal filter pressure after filter clean, 22 psi. When I did the bw yesterday it was 25 psi. Good flow from all the jets in the pool.
Both venturi valves were closed(2nd pic, 2 valves on left closed). Main drain closed on suction line. Hope that makes sense.So you should not close both skimmer valves and the main drain valve unless there the SPA main drain is open. Maybe I don't understand what you have done. Maybe a picture of how you have both valves and main drain closed.
