- Jul 1, 2024
- 5
- Vinyl
- Hayward Aqua Rite (T-3)
Second season of managing this pool after moving into a new house. Almost didn't look at the house because it had this pool, but it's become somewhat of a pet project. With the help of a very kind neighbor and being introduced to this site I sailed through last year, but have been having some unexpected trouble after opening this year. I have a pool guy who helps open and close, but for the most part am trying to deal with the day to day myself as much as possible. Water looks pristine.
8000gal (to my best guesstimate), SWG, vinyl lining
pH 7.5
FC 32.5
CC 0.5
CYA 100
TA 80
CH 100
Salt 3200
I had hoped my first post would be solely about trying to optimize my pump run time with the SWG (currently 8 hours at 50% - a mix of what my pool guy last year initially suggested and what ultimately worked to keep the levels right), but an incident last week with a pretty significant leak from the inlet to the pump had me worried I'd have to leave the pump off as much as 3 days and I added too much shock to prevent algae. Story short, issue was mostly corrected (still a slow ooze, but that's another question), but I clearly overshot the chlorine levels.
1) Is there anything I should be or could be doing to bring down the FC (I know the high CYA doesn't help this)? Can I be lowering my SWG on percentage? If so, for how long? For what it's worth, I've been in the pool and the elevated chlorine hasn't been bothersome.
2) Despite this, is it really necessary to replace water to bring the CYA down 10 (no idea how the level got to where it is, I used poolmath to calculate moving it from 0 to 70 when I opened the pool)? I'm worried about overshooting in the other direction.
Salt is at the desired level. Pool has a small fountain and a step jet that aerates as it returns so I know the pH will come up without much intervention.
Appreciate your thoughts.
Thanks.
pH 7.5
FC 32.5
CC 0.5
CYA 100
TA 80
CH 100
Salt 3200
Thanks.
