Is there an optimal order to add these: acid before liquid chlorine, or liquid chlorine before acid?
I am not talking about huge changes like startup or SLAM. I'm talking about normal small maintenance doses during the week. I usually add in the evenings. I wait a little bit between adding the two chemicals.
Most 'order of adding' chemicals articles I see suggest adjusting the pH first before adding sanitizer, but these seem to be talking about large adjustments which is not what I'm asking about here. What got me thinking is liquid chlorine additions raise the pH a little. I understand this is a net-zero effect, as LC temporarily raises the pH but then it drops again as the chlorine consumed. However, I add LC at night where there is little-to-no chlorine consumption, which suggests my pH remains slightly elevated all night due to this effect.
Would adding acid after the liquid chlorine help minimize this effect? Or is the end result the same regardless of the order? I don't know the chemistry well enough to know if it matters, but it seems (?) that a given amount of muriatic acid has larger downward effect when the starting pH is higher, which could suggest adding LC before acid is better.
And yes, I fully realize I'm overthinking it and the difference, if any, is small.
But this is a zero-cost thing for me so if one way is better then I'd like to adopt that approach.
What do y'all do?
What do y'all do?
