- Oct 25, 2015
- 5,801
- Plaster
- CircuPool RJ-60 Plus
Folks,
May of this year we filled up our brand new OB pool with a combination infinity edge and zero edge. I'm finding there are a few things that are a little different about its operation so I thought it might be helpful to others that I start this thread as a place where we can assemble learnings and tips specific to these types of pool. Here's my first entry:
My pool has a zero edge around all the edges and infinity over the back edge closest to the lake behind our lot. (recent photo below) 3' below this edge is a catch basin that has two large suction fittings in the bottom which is another 3' below. It's also 2' wide. I was very concerned during the design phase about how to control level since this little basin holds only ~1500 gal compared to the pool volume of 28,000 gal. Turns out it's very easy to control since there's way less time delay when people enter the pool and displace water over the infinity edge. I had planned to use a high level normal level and min level with some unnecessarily complex control. Turns out it's very easily controlled with a single simple float switch type level control set normally about 8" from the bottom. I use this to add water from my irrigation well pump via a pipe that fills the basin directly and it has a simple, inexpensive sprinkler valve. So long as the basin has plenty of volume to handle a lot of people this works great. Each time somebody gets in they displace 23 gal of water over the back edge. So even 5 or 6 is way less than my 1000+ gal capacity. For people that use the smaller horizontal buried surge tanks this could be a bigger issue. So while I was all consumed (over-consumed) with the level control response time I didn't think much about what happens if the level switch failed closed. Right after I added 3500 ppm salt and before I turned it on I had to take a business trip for a week. So I left and my wife just added liquid chlorine. I looked at the pool each day through the security camera that I accessed with my phone. After a few days the pool changed from it's normal gorgeous crystal clear to slightly greenish then deep green. We had massive amounts of rain that often happen this time of year in S Florida. So I had her add 4 ppm chlorine. This helped but didn't solve it so we doubled the addition. This cycle repeated till I was adding 10 ppm per day. This was LOT of chlorine since the pool is 28000 gal. But it was barely enough and 10 ppm is SLAM level for my CYA level (still low for this newish pool). When I finally got home after the flights from H**L we get these days it was 2 am so I went straight to bed. Woke up next day and thought I heard a pump running but that's normal for the irrigation pump. So I got up slowly, had a few cups of coffee and eventually wandered out to look at our gorgeous pool from the patio... only it was now really deep green and the back of my yard below the pool was flooded! Not from rain but from my pool. The level control had failed and ran the irrigation fill all week long 24 hours per day! The green color came from the tannins in the well water that are yellow until oxidized with chlorine. Yellow plus blue background from the plaster = green. Thanks @JoyfulNoise noise for that tip from construction when we first started it up. I quickly went to a manual mode on the level control and am now incorporating a high level shut down plus a low level shutdown to prevent pump damage. Very easy to do and yes, necessary for this type of pool.
I hope this is helpful to someone with a similar pool.
Chris
Chris
