Hello there. Just bought my house with pool and I'm doing what I can to learn. My pool has a slide but when I turn the water valve it barely trickles down from about 1/2 down the slide and nothing comes out at the top. If i remove the hose feeding the slide from the valve i can put my finger over the outlet and stop the flow of water. My pool guy who I fired originally told me he thought the second pump was to run the slide, but I believe it's actually for a Polaris vacuum that is no longer here. When I turn that pump on a 3rd center jet in the pool blows water out just below the slide and it actually kills what little pressure the slide had. If that 2nd pump is off I can still feel water coming out of the center jet, but it's weak pressure. The other two jets have really strong pressure. Please advise how pools slides are supposed to work, so I can troubleshoot the low pressure. Pics attached of everything involved. Thanks in advance
