So I've read several previous articles about this topic on here and have had it done on my pool before, although the plaster layer that is on now is newer and different (Sider-Crete's roll on plaster). In applying the new plaster, there were areas I believe got "over-worked" in trying to get a smooth surface and have what I believe is just efflorescence that formed after the plaster cured. Additionally, an unfortunate rain shower also left water trails down the walls. The company suggests using Sure Klean 600 to remove this, but I would have to drain the pool - not a real issue as it's only 2000 gallons, but I'd prefer to avoid doing that. Another possibility I ran across was using Pool Stain Remover's $245 treatment, which can be done without draining. Judging from their before and after photos, it seems their product does a great job.
Currently, I am at about day 4 in this process. My water is cloudy so I can't really see the deeper part of the pool but it appears the water trails have been greatly diminished, however the areas in the "over-worked" areas don't show much difference at all. Since my Taylor test kit doesn't go below 7.0 pH I have no real idea how low the pH is. I have added roughly 3 gallons of MA, including another 1/2 gallon today. Two days ago my alkalinity was about 70 ppm but now when I do the test where you add the 2nd reactant, instead of turning green, the sample turns red so I have no idea what that means....that alkalinity is at 0? My calcium hardness has risen from about 280 and now sits at 400-440 ppm.
I'm not concerned about losing a bit of plaster doing this process. I am satisfied with the Sider Crete product but my attempt at trying to duplicate my original plaster color feel a little short, although the current color is nice, just a bit too turquoise for my tastes. I might attempt one more try at creating a better color but that's not the main issue. My question is how can I test for a really low pH? Take a sample to Leslies? Also, at what point should I try to address the cloudiness and how? Seems like draining some water is inevitable. Also, just how often are you supposed to brush the pool while doing a no-drain? Thanks!
