I've lived in Colorado for 4 years and got the wild hot tub hair for the star filled sky and yard. We're only gonna use it every other weekend and then treat and drain for a couple of weeks until next fill and reheat. There may be 3 to 4 soaking hours of use each refill, or 1 hour a day average over the weekends it's used.
It has two paper filters and is a SaluSpa Realtree MAX-5 AirJet 4-Person Portable Inflatable Hot Tub Spa.
I know ZERO about safe spa water so please tell me if this will do for upkeep if the water smells and looks OK when it's filled and used:
1. I've used it for first time this past weekend. I filled it Friday 4pm with 180 gallons of softened well water and put 2 fluid ounces of 8.25% liquid household bleach into it and let it heat up to 104 degrees F. This took 24 hours to heat up.
I looked and smelled the water Saturday night 9pm and it seemed fine, maybe a slight hint of chlorine...either that or the new plastic smell from the tub construction. 3 people got in it for 45 minutes. I put the cover back on and then Sunday at 7pm I put another 2 fluid ounces of 8.25% chlorine bleach and used it again for 1 hour at 9pm, allowing it to breath for 15 minutes with the cover off before getting in.
When finished I put the top on, turned the heat off, put 1 cup (8 fluid ounces) of 8.25% bleach into it and let it circulate until next morning. I then drained the tub and pump/heater unit and let it dry as best I could in the dry Colorado shade. I rinsed and dried the paper filter elements that still looked very clean.
2. Will this treatment plan be okay ya think, as long as the water looks and smells clean or neutral? Do I need a testing kit for anything? I want to keep this as low maintenance as possible so I don't get tired of it.
3. Am I using too much or not enough 8.25% chlorine? I'm using slightly more (it says 1 teaspoon per 8 gallons drinking water) than the amount the EPA and CDC webpages say to use to make drinking water safe. I figured if it makes it drinkable it may be enough for my use type.
If you can tell me the best and easiest way to tend to this little tub, used occasionally, I'd appreciate it a lot! For supplies, I have a Walmart nearby, and am an Amazon user also.
Thank you! Andy
Thank you! Andy
