Hello everyone,
I am in the process of setting up my pool on the Pool Math app. I have a large pool (~29,000 gallons) and a small attached spa (~1200 gallons). The spa overflows into the pool. When I set up the "pool" in the app, would I set up as one system or treat it as two different pools.
I'm not sure if it matters, but I got the water tested (two different samples) at my local pool store and the differences in test results were negligible between the two. The exception would be "calcium hardness". The pool was almost 3 times higher than the spa.
Thanks for your help!
