Good morning! Recently a friend told me about how he has been using your site to keep his pool well balanced and maintained - so I have been trying to learn how to get my pool chemicals adjusted using the method described here. We have had a few issues with our pool - first of all I live in Mexico and we had our pool built a year ago by a company that we have since heard from others is not that reputable. We also let the pool go without keeping the chemicals up while building the surrounding patio - so that was definitely our fault - and we had a lot of algae. We have since had the pool serviced and up to this point we were using the Tri-Chlor chlorine - as well as shock. But I bought the Taylor 2600 test kit and just ran the numbers for the first time. We are past due for adding chlorine - but I wanted to see what else I need to adjust before adding chlorine. Thanks for your help and understanding - I am a complete newbee to pool care, but really want to learn how to take care of it ourselves. Here are my readings:
Pool size: 12.500 gallons
Free chlorine - 1 ppm
PH: 8.0
Acid demand - I need help with this one - it took 6 drops to bring the PH down to 7.4 - so according to table E in the booklet we should add 1.72 quarts + 2.2 fl ounces of muriatic acid.
Alkalinity: 150 ppm
Calcium Hardness: This came out super high - it took 32 drops to change the color to blue so that means it is 320
CYA: 100
We use well water in our pool - and we are in a rural environment (24 acre property) with organic matter getting into the pool (seeds blowing in) - and dirt blowing in. We are going to landscape more around the pool to try to cut back what blows in, but meanwhile we are using the net to skim the pool twice a day, and running our filter 6 hours per day.
We have seen a lot staining just recently - and when we had the pool serviced, the service man said he couldn't get it off with our brush - which is mostly plastic with some steel bristles. I just ordered a totally steel brush to try to get that off. I'm attaching a photo of the stains.
So my questions are: How to balance the chemicals in the pool? What do we do about the calcium hardness? Do we need to drain? Is there a way to get rid of the stains? Any other counsel? Thank you so much!
PH: 8.0
Alkalinity: 150 ppm
CYA: 100
