Just bought and installed a new Hayward above ground pool pump. The first time I turn it on, it was whisper quiet. I turned it off, and turn it on the higher speed, and it immediately started to whine. I turned it off, and turned it back on low, and now it's whining.
I had to redo the plumbing, but I installed a 1.5 inch high pressure spa hose between the pump and the sand filter. All the rest of the hoses are the same as the old pump.
Before I assume this is a DOA pump and get a new one, I just want to make sure there's nothing else I could have done wrong to cause this. Poor water flow? Is the pump oversized somehow? Not sure how to check these things.
New video by Eric Daniels
photos.app.goo.gl
