Hi all! Been lurking awhile and soaking up as much info as I can! Here is a little bit about the potential project. We would love any and all input as we feel that fellow pool owners would be the best source of info and input.
My wife and I have a piece of land up in Lake Almanor California that we purchased years ago that we are finally in the process of designing a garage/guest house and main house. The rough location of the house is on a slight upslope on the lot with the ‘face’ of the house facing away from the hill. While with the architect/engineer I jokingly mentioned since we have to dig into the hill for a foundation/basement, we might as well dig deeper and do a pool in the basement. The engineer grinned, I grinned, wife…not so much. She is slowly getting on board with the idea, with time I think she will join ‘team pool’.
We are DIY’rs by heart, I’m a fan of overwhelming projects and we are planning on doing all but the concrete/foundation work on building the garage/guest house, main house, and pool although this project combo is close to the largest undertaking we've done. Digging a giant hole has always been on my bucket list, and digging for a pool should take care of that!
Here’s and overview of what we are thinking. Any input/opinions would be great!
[*]Fiberglass pool, more than likely from Viking as we are just a couple hours away from them.
[*]The pool size is probably going to be limited to the 12’ x 26’ range. Between the weight of the house above, the snow load, and the span of the ceiling above the pool, the huge limiting factor (hopefully not the killer of the idea, tbd by engineer) is beam/joist/footing sizes.
[*]The pool room would be in its own envelope isolated from the house with a non permeable barrier. Rough numbers are coming out around 10,000-12,000 cubic feet of air space that would need to be dehumidified and conditioned.
[*]Pool temperature around 82, room temp around 84.
[*]Heat pump for main heat, supplemented by propane for colder months. There is no chance at solar, the house/lot is surrounded by pine trees and is heavily shaded.
[*]As automated as possible, we live about an hour and half away, so always getting up there may not be possible all the time. One of the big plans is to rent the house out weekly during the summer to vacationers. So being able to remotely monitor how the pool is doing would be needed.
Questions / input we are hoping for:
[*]We are leaning towards running it as a salt water pool, but a bit concerned about corrosion. Would running a uv system combined with salt water allow us to reduce the levels of salt/chlorine in the pool in turn hopefully reduce the speed of corrosion?
[*]For the pool chemical gurus, what does the lack of sunlight do (or not do) in indoor situations?
[*]From research it looks like the rule is always have the room 2 degrees warmer than the pool in order to keep condensation relatively under control. When the house is being used the plan is to run the pool at 82, and room at 84. Now if there’s no vacation renters, or we are not up there and its mid winter and snowing is there any reason the pool/room temperatures can’t be dropped to, say, pool 50 room 52?
[*]Some type of cover seems to be a requirement for indoor pools. Any chance a liquid cover would work in this situation since wind seems to be a problem causer… or is it still snake oil?
[*]Any opinions on automatic floor cleaners? Leaves and such should be limited being inside, but not being close all the time to it is the concern.
Any and all input welcome! Thanks for everyones’s time!
