Hey everyone,
I'm a relatively new pool owner (9 months) and have a 14,500gal in-ground pool/spa. I've never had any issues with my chemical levels (tested weekly) until I recently started seeing mustard algae growth after a few birthday pool parties (in September and October). My kids also brought dirty/sand/saltwater body boards into the pool which I also suspect contributed to the recent algae growth.
To combat the algae, I started with raising chlorine levels, which didn't work. I then tried Clorox algaecide, which worked for a short time, but then the algae returned in full force.
After these initial attempts, I then removed and cleaned all of the pool filters, replaced the pool cartridge filter, increased chlorine levels, started brushing with a stainless steel brush (as opposed to nylon), and used "Yellow Treat" along with aglaecide and additional chlorine. The algae is nearly gone, most of which I credit to the stainless steel brush helping to remove it from the textured pebble/plaster floor.
However I still see slight staining and a few slightly yellow areas in the dark corners of the pool, and I'm having difficulty raising the chlorine levels. I've been using a Clorox shock product and even after adding, I barely get a reading on free or combined chlorine.
Where should I start? My CYA levels are not high and all other levels seem within range. Is my CYA level perhaps too low? Photos attached for reference.
I have a lot to learn but I appreciate your help!
EDIT: after doing some more reading, I've already ordered a Taylor K-2006C test kit, so stay tuned for results.
