We are in the process of meeting with Pool companies to build a SWG pool in League City. So far we have 2 quotes but are leaning toward the 2nd. We want a spa, waterfall and the option to add a slide (typhoon) later. Here is the 2nd pool builders design (we had him change some things and delete the landscaping for now).
CUSTOM POOL PACKAGE INCLUDES: (33 ½’ x 16 ½’)
CUSTOM SPA PACKAGE INCLUDES:
MOSS ROCK WATERFALL…………………….………………….…………... 4 TON MOSS ROCK WATERFALL
NATURAL STONE SEALER…………………………………………………….2 GALLONS STONE SEALER
ADDITIONAL TRISTAR EE PUMPS……..……………….………..2 HP (Includes all Plumbing & Electric Runs)
ADDITIONAL HAYWARD LED LIGHTS……………………… POOL
AREA DRAIN…………………………………….………...........................ADD 150’ OF 4” AREA DRAINS
ADD 3 CATCH BASINS
PLUMBING FOR FUTURE SLIDE………………………………………………….
(Includes Suction & Return Lines)
My Questions?
Does this pool equipment look ok?
Do I need to seal the travertine and our flagstone patio?
- UP TO 80’ PERIMETER POOL 6’ MAX DEPTH W/ 1 ¼” EASED EDGE TRAVERTINE COPING & BASIC 6” WATER LINE TILE
- 9-11 RETURN LINES (VARIATION IN HEIGHT) & 3 BUBBLERS
- 2 SKIMMERS with 2” SUCTION LINES ON 45* ANGLES
- 2 ANTI-VORTEX MAIN DRAINS with 2” SUCTION LINES ON 45 ANGLES
- STEEL DETAIL: 3/8” REBAR 8” O.C., 4” O.C. ON ALL DEPTH TRANSITIONS GREATER THAN 5’ IN DEPTH, 4 - #4, ½” REBAR ON BOND BEAM
- GUNITE SHELL: 6.1 (SACKS/SAND) RATIO; 4000 PSI
- POOL EQUIPMENT PAD, SHOT with GUNITE & STEEL REINFORCEMENT
- HAYWARD ECOSTAR VARIABLE SPEED EE PUMP
- HAYWARD C 7030 CARTRIDGE FILTER
- 2 HAYWARD UNIVERSAL LED COLOR POOL LIGHT
- AQUA LOGIC CONTROL SYSTEM WITH WIRELESS AQUA POD REMOTE
- HAYWARD AQUA VAC POOL CLEANER w/ GFCI OUTLET (if needed)
- AUTOFILL / OVERFLOW SYSTEM
- AQUA RITE SALT SYSTEM - 40,000
- PLASTER FINISHES; QUARTZSCAPES: Barbados Blue Plaster Option
- 7 ½’ ROUND SPA w/ 18” BEAM, RAISED 12”, 3’ MAX DEPTH W/ 1 ¼” EASED EDGE TRAVERTINE COPING, SPLITFACE STONE OR 6” BASIC TILE SPA SURROUND AND 6” BASIC WATER LINE TILE
- 6’ FLAT SPILL WAY
- 8 HAYWARD MASSAGE JETS w/ PULSE-FLO & ADJUSTA-FLO HEADS
- 2 ANTI-VORTEX MAIN DRAINS with 2 1/2” SUCTION LINES ON 45* ANGLES
- HAYWARD H-SERIES 500,000 LOW NOX HEATER
- SILENCER 2 HP AIR BLOWER
- HAYWARD UNIVERSAL LED SPA LIGHT
ADD 3 CATCH BASINS
My Questions?
