Local pool store installed a new Latham liner at the end of November, 2024.
Recently while servicing the pool I noticed an area where the liner is sagging down. Upon inspection it seemed like there were two issues:
1. Detaching - looking downward, you can see the wall behind the liner (easier to see in person)
2. Vertical seam starting to separate
Here are a couple of pictures:
Installer contacted Latham and a leak detection company. Regarding the vertical seam separation, both Latham and the leak detection company said it's not actually a seam separation, and that it's expected to look that way. For the detaching, the leak detection company said that can happen sometimes when the liner starts coming off the track, so they pulled it back up and reattached.
Are those accurate responses and actions in terms of the vertical seam and separation from wall? Visually it looks like that seam would keep separating downward. Any long term concerns with the liner already coming off the track? Can that just happen sometimes and doesn't matter as much that the liner was just installed?
