Hi. New to hot tubs, but a 2-year pool owner following the methods outlined here for pool care (successfully, I might add
). Looking for some advice about hot tub startup/what to expect. Never had a hot tub. Never had a family member or close friend with one either, to go off of.
Dealer-installed new 325 gallon PDC Spas Catalina hot tub yesterday. Dealer includes (i.e. we pay for, lol) with purchase all their recommended "startup" chemicals, for better or worse (assortment of bromine tablets, pH up/down, TA up/down, sodium bromide, "activate granular" (is that MPS?) and "calcium booster."
325 gallon acrylic spa with ozone system as part of filtration (when main 2-speed pump is on low speed, ozone system is on, from what I gather)
Bromine tablet feeder tube installed in filter chamber
Fill water at 5pm - pH 7.2 | TA 10 | CH 25 | some presence of chlorine | 60 degrees
TF100 Pro test kit, brand new for the season
Dealer installed and showed me how to set the pump speeds, heat settings, filter cycles and briefly talked about chemicals. He didn't seem to believe in the significance of balancing CH and TA, and just said that sanitizer is king and pH matters only a little. Funny, considering they have a bundle of chemicals "included, lol" that would be used to balance those things. I figured I'd be on my own to do my water the right way anyway. The only thing he said about testing is "let us test your water once in a while, to protect you on warranty claims," but doesn't believe in 2/3 of the water chemistry.
I intended from the beginning to follow the sticky thread from this forum How do I use Bromine in my spa (or pool)? In doing so, made my first addition of a packet of 2oz Sodium Bromide (supplied by dealer) - about only 1.625oz was called for based on volume, but I inadvertently added the whole packet, so an extra 3/8oz. Hopefully not a problem. Next, slowly started adding calcium to get nearer to 100. Intended on doing this in doses because the provided chemical from dealer does not list the working ingredients anywhere I can find Sirona Calcium Booster, so I don't want to overdo it (it says 1oz would raise CH by 7ppm in 500 gallons, so by my math about 10ppm in 325 gallons - I don't know what that corresponds to in Pool Math - never had to add calcium in my vinyl pool). Over the evening I added 6oz of that. Added 3.1oz baking soda, per Pool Math, to raise TA. Tested a couple times as the hot tub came up to temp, dosing calcium booster twice. Also filled up my feeder tube with the bromine tabs and only left the minimum flow adjuster open. I can always open it more. I'm not yet sure how the ozone/bromide reserve/bromine tablet relationship shakes out, but I assume the ozone, when running, will oxidize some bromine as active sanitizer.
Anyway, as of midnight, about 7 hrs after fill, the tub was reading pH 7.8 (not sure why it went up so much from 7.2 - maybe aeration, despite the low TA?) | TA 50 | CH 100 | some presence of bromine | 96 degrees. Wife and I thought we'd give it a try since we waited all day, as parameters were in ranges. Soaked about 20 minutes. After we got out, I decided to give it a shock dose of the MPS (I assume that's what potassium peroxymonosulfate is, though I keep seeing potassium monopersulfate - is that just a difference in how the name is written?). I couldn't find MPS on Pool Math so I under-dosed according to directions on the bottle, and added about 2oz around 1am last night.
So as of this morning, the testing reads pH 7.5 | TA 40 | CH 100 | high presence of bromine according to OTO test - question below | 100 degrees. I think the MPS has some properties that would lower the pH/TA a bit? Water looked nice and clear. The only thing I noticed is that around the waterline, there was some... scum? Not really scum. Looked like a sort of off-white powdery/granular dust, but when wiped with a finger it sort of accumulated into what I can best describe as a blob of dead skin/grease, but not sure if that's what it is. For what it's worth, we'd both already showered before getting in. We'll probably never be that clean again upon getting in, haha. So my questions:
- Is accumulation around waterline as described a normal occurrence in acrylic tubs? I don't think I'd ever been in one before. Is something off, or is that just something I'll be wiping regularly? It was mostly in the area of seats we had been sitting in, but not exclusively there.
- I'm not great at reading the OTO color blocks. I usually use that to test for general presence of sanitizer. Can the FAS-DPD (chlorine) test be used to test for sanitizer amounts, and then multiplied by 2.25 to get exact bromine level? I did that this morning, and got 5 FC => 11.25 bromine, which aligns with the dark yellow OTO test. Is that valid?
- Never used MPS before - is that what I have? - and for my system, will I only be using that as a shock oxidizer periodically as needed? Should I be adding any sanitizer (MPS is not sanitizer, itself) on each soak, or is that what the bromine feeder/bromide reserve/ozone system is for? I can also use 10% liquid chlorine for shocking, I just won't have any on hand until this weekend when I'm opening the pool, so I used MPS to get started with an initial shock of the water last night. I probably will, as I'm more comfortable with handling that. Does that mean I'll calculate enough liquid chlorine to raise FC to 4.5 => ~10 bromine for shocking?
- Did anything in my process above stand out as a bad thing? I'm new to hot tub care, but not gonna lie, I have sort of come to enjoy my water chemistry. I just want to make sure I'm getting off on the right foot and don't have anyone to personally ask for experience. If I'm following the sticky, I'm aiming for those numbers - TA 50-60 | CH 100-125 | pH 7.4-7.6 | active sanitizer bromine 4-6ppm | 98-102 degrees based on bathers
- I'll be back to ask later about drains and refills. I like the people at the pool store on a personal level - they're friendly. But I don't really trust all their advice. I take it with a grain of sodium chloride.
