Hi all,
My wife and I purchased a 1200L hot tub and spent the first few months going in with water samples to attempt to get the levels right. Out of frustration, we've since purchased a Taylor K1005 test kit and it is my hope that combined with the PoolMath app, we can get a handle on things and free ourselves of running into town to get things dialled in. The test strips we were using are just too vague for us, at least at this point in time.
With the Taylor Kit (first use this weekend), I got the following readings:
Chlorine (used the 'half diluted' method):
Free: 2 ppm
Total: 3 ppm
Combined 1ppm (x2) = 2 ppm
PH: 7.6-7.7 ppm
Alkalinity: 3 drops of reagent x 10 = 30 ppm
Hardness: 20 drops of reagent x 10 = 200 ppm.
According to the app, we were to add 84g if Alka-rise, which we've done. I typically put 4 tabs of chlorine in the floater and open it up to about 1/8" exposed. I think all is looking good and just wanted some clarification on the 'Free Chlorine' tab in the app.
If I enter 2ppm in the first field 'Current Free Chlorine', is the CYA field necessary? Also, and this is my main question, what does one enter in the 'Target' Free Chlorine' field and how does 'SLAM' affect things? What should be entered in the input field beside the 'Slam' option (and should that be checked)?
Our weekly basic schedule for chemicals has been:
-Mike
Free: 2 ppm
Total: 3 ppm
PH: 7.6-7.7 ppm
- Test and adjust pH / alkalinity as needed (we add the chemicals dry to the surface of the water with main jets off, circulation pumps on and cover off), wait 20 minutes.
- Add 1 oz 'Prevent' (anti fungicide), wait 20 minutes, cover off
- Add 1 oz spa-shock (sprinkle over the surface of the water) and wait 20 minutes, cover off
- Add 6 oz Aqua Finesse (not sure if this is necessary. The dealer recommended it but it's pricey).
-Mike
