in-ground pool. Approx 16 x 32. Vinyl, chlorine pool.
noticed this last summer a few times. Replicated today.
stuck my finger into pool water. Have a small cut on finger. Noticed a slight tingling sensation. My toddler aged nephew indicated he felt same last summer a few times when grabbing one of the rails at end of pool upon exiting pool.
I turned off the breaker for my pool light. placed finger on water again, made no difference as I still felt sensation.
I traced the bond wire from where it attaches to the pump motor to where it goes under the concrete at edge of pool deck. Wire was intact. I did hand tighten up the wire on the nut at the pump as tight as I could - already seemed quite tight but I tightened it a small bit more.
stuck finger in water again. No tingling sensation. But I really don’t trust that this solved anything given this is electricity we are talking about.
I should mention last summer I had a guy here to look at another pool issue and he checked the pool light and told me everything seemed to be wired properly at the light. He was not an electrrician but did work on pools. He tested the conenction at the light and said it was fine.
any thoughts?
any thoughts?
