- May 6, 2020
- 24
- Plaster
- Pentair Intellichlor IC-40
Hello everyone! We're just getting started on a new pool build at our new house in Austin, TX. After following so many threads here on TFP and learning a TON, we decided to go the BYOP route and I'll be managing the build (and possibily doing some of the work myself where it makes sense) rather than hiring a pool builder.
Here's what we have so far:
Here are my outstanding questions that I'd love some advice/feedback on before I send them over to be finalized:
Total equipment list Ive come up with (all Pentair):
And now, for the pictures!
- Pool Size: 18' x 32'
- Pool depth: 4' to 6' (depth from middle of waterline tile)
- Tanning ledge: 7' x 21', 9" deep (from middle of waterline tile)
- Spa: 8' x 8'
- Total volume: ~11k gallons
- We're planning on a salt water system and going with all Pentair equipment (the site plan attached doesnt reflect that yet). I know the common wisdom is to pick a cell that's 2x your pool volume, so it seems that would put me in the IC20 range, but I only see Intellicenter bundles that come with the IC40 or IC60 cells. Am I left with buying the IC20 and Intellicenter separately (or maybe there IS a bundle and I just missed it), or should I just go with the (likely oversized) IC40?
- They spec'd a 400k BTU propane heater. We're only planning on using the heater for the spa, so is that overkill? The main deciding factor here is if I can get a 2" propane line to the pad, which is what the site plan is calling for. I know I can get a 1" line over there which is what I saw as a requirement for the 200k BTU heater (looking at the Pentair Master Temp 200k propane model)
- Is it worth it to run electrical and plumbing for a chiller? We're in Austin; it's been over 100 degrees here for what seems like forever this summer. Those of you that put one in, was it worth it? Would love opinions on Glacier chillers vs. a heat pump system.
- Number of skimmers: current plans only spec out 1 on the top right corner of the pool. Is that sufficient or should another be added?
- Im planning on using Pentair microbrites. They've spec'd 5 total: 4 in the pool one in the spa. This seems like it should be sufficient.
- Intellicenter with IC20 or 40 salt cell
- IntelliFlo3 VSF 3.0HP pump
- MasterTemp 200k BTU heater
- Clean & Clear Plus, 420 Sq. Ft. Cartridge Filter
- Microbrite color LED lights (x5)
- Pentair IntelliValve actuators (however many I need...)
- Check valves (Pentair? Jandy? Other?)
- Diverter valves (Jandy never lube? Pentair? Other?)
- Blower for the spa
- Anything else I might be missing
